Skrevet av Emne: Sivrt`s Jeep garage.  (Lest 170556 ganger)
Utlogget sivrt
Re: Sivrt`s Jeep garage.
« Svar #345 på: Lø.,23,Januar,2010,19,49 »
Da var endelig bestillingen til 4wd.com sendt.. Så nå er det bare å lene seg tilbake å vente på at det skal bli julaften på Flåklypatoppen
En "liten" liste...
Order Summary Quantity Price
X-Joint with needle bearing by Alloy USA
Part # ALY11500
up to 15% off sitewide 3 $102.57
Spicer 1310 Driveshaft U-Joint by Dana Spicer
Part # D/S5-153X
up to 15% off sitewide 2 $30.38
Power Lead Quick Connect by WARN®
Part # WAR22680 1 $39.99
Quick Connect Dust Cover by WARN®
Part # WAR69847 2 $31.98
Spicer 260x Axle Shaft Universal Joint by Dana Spicer
Part # D/S5-260X
up to 15% off sitewide 3 $105.42
3-Way Mobile CB Antenna Mount by Firestik
Part # BRJ300-K64A 2 $27.98
Glow in the Dark Tire Pressure Gauge by Joe's Racing
Part # JRP32307
up to 15% off sitewide 4 $107.96
Rear Axle Snubber by Crown Automotive
Part # CRO52002393
up to 15% off sitewide 2 $16.18
Liftgate Shock
Part # CRO55076208AB
up to 15% off sitewide 2 $55.78
2-1/2 Gallon Air Tank by ViAir
Part # V/A91025 1 $69.99
Softride Nitro Shock by Skyjacker
Part # SKYN8025
up to 15% off sitewide 4 $151.16
Part # SKYN8028
Part # SKYN8049
up to 15% off sitewide 2 $75.58
Part # SKYN8063
“Dually” Twin Cylinder Portable Air Compressor by Smittybilt
Part # S/BQ89
up to 15% off sitewide 1 $118.99
X Factor Steering Upgrade by Rock Krawler
Part # RKSTJ88004
up to 15% off sitewide 1 $341.99
2008 Top Truck Challenge DVD
Part # VIDTTC08DVD
up to 15% off sitewide 1 $22.49
Shift Linkage Grommet by Crown Automotive
Part # CRO53004810
up to 15% off sitewide 3 $5.37
Seal Output Shaft by Crown Automotive
Part # CRO83501389
up to 15% off sitewide 3 $8.07
Shift Linkage Repair Kit by Crown Automotive
Part # CRO5014148AA
up to 15% off sitewide 1 $12.59
Utlogget sivrt
« Svar #346 på: Fr., 5,Februar,2010,22,00 »
Idag har jeg sjekket ut noen ulyder under bilen rundt transferkassen. Har hatt en dunkelyd spesielt ved pådrag når 4 hjulstrekken er på. Lyden er ikke der når jeg bare kjører i 2wd. Det er en liten slakk i foringene som fester stagene mellom spaken og transferkassen som kanskje kan lage denne lyden, de foringene er på vei fra 4wd.com.
Tenkte kanskje at ved pådrag i 4wd vil transferkassen vri seg noe pga kjedeoverføringen. Tok derfor ned warn skliplaten siden det er nokså liten klaring mellom denne og transferkassen. Der fant jeg et lite felt, som en 10 øring, som var slitt.
Siden jeg ikke har vært nedi med denne noe særlig regner jeg med at lyden gjerne kan komme fra dette. Shimset skliplaten ned ca 2mm, håper dette funker. Nye foringer blir montert uansett når de kommer.
I verste fall kommer denne lyden fra innmaten i kassa, da blir det overhaling av denne i tilfelle. Men tar det enkle først.
Forhåpentligvis forsvinner lyden i 4wd nå, har ikke fått tatt den en prøvetur enda..
Fingers crossed...
Utlogget sivrt
« Svar #347 på: Fr., 5,Februar,2010,22,02 »
Fikk også sjekket litt på T-Max vinsjen som jeg skal ha i krybbe og brukes bak på XJ`n og evnt foran på WJ`n.
Ville gå over girhuset siden jeg måtte overhale dette på Tabor vinsjen jeg har foran for en tid tilbake. I Tabor`en var det et sort fett som minnet mistenkelig om MoS2 fett. Pusset derfor opp alt i den og satt den inn med MoS2 fett igjen. Den fungerer helt perfekt.
Men, i T-Max vinsjen viste det seg et brunt særdeles seigt fett når jeg åpnet den. Hva slags fett er dette og er det sånt fett som egentlig skal brukes? Eller kan jeg bruke begge deler tro?
Ellers så drevene helt fine ut og frie for rust og vann.
Noen som har erfaringer eller sitter på annen info om hva slags fett som er foretrukket på vinsjer i girhuset?
Noen bilder av T-Max vinsjen og fettet som er i den:
« Svar #348 på: Lø., 6,Februar,2010,11,31 »
Ser ut som noe billig animalsk fett.
En liten digresjon men A dykk tok for noen år siden inn 20 billige kina undervannsscootere. Fettet som var på O ringer og også plastdrivverket lignet veldig på det som er i T maxen din. Vi gjorde reint scooterene og satt alle dele inn med silikon. Da gikk de faktisk bedre og min har vært tett til 35 meter, mens de orginale sprang lekk på 10 meter.
Jeg ville ha gjort alle delene rene og satt alt inn med MoS2 eller lignende fett.
Utlogget sivrt
« Svar #349 på: Lø., 6,Februar,2010,22,31 »
Var inne på samme tanken Kjetil. Selv om det ser ut som om dette fettet kan være en heller PITA å få rengjort skikkelig..
Får ta en tlf til Amund kanskje, de burde vel ha en anbefaling på dette. Eller kanskje de kunne sjekket det opp mot f.eks Warn..
Tok forresten en prøvetur idag med XJ`n og det viser seg at ulyden er borte vekk Deilig når det er så lite som skal til for å få ting i orden.. ;D
Har også fått kjøpt inn stålomspunnede slanger og filter til å forlenge luftingen på begge kassene. Kjøpte også et 12V uttak som skal monteres bak i lasterommet og noen sikringsholdere til montering av diverse elektrisk utstyr baki der.
Utlogget sivrt
« Svar #350 på: Ma., 8,Februar,2010,23,39 »
Slenger inn en film av XJ`n tatt på siste kjøring 07.02.10
60-70cm jomfrusnø, dvs aldri kjørt på, + tung høyrefot = Veldig morro
http://www.youtube.com/user/Sondref150#p/a/u/0/jBXlTi8Iro0
« Siste redigering: Ma., 8,Februar,2010,23,52 av sivrt »
Utlogget sivrt
« Svar #351 på: Ma., 8,Februar,2010,23,43 »
Hmm, går det ikke å få inn filmen i et vindu her. Samme vindu som kommer opp på Youtube.???
« Svar #352 på: Ma., 8,Februar,2010,23,51 »
Du har ikke linket til hele adressen. Trykk på linken din og du skjnner det...
Linken viste feil retning...
Youtube hadde tidligere en SHARE funksjon for .php forum, men jeg fant den ikke igjen via youtube siden din.... Der var det bare SHARE linking til sosiale medier alle tryneboka osv.
« Siste redigering: Ti., 9,Februar,2010,00,03 av Stein-K »
Utlogget sivrt
« Svar #353 på: Ma., 8,Februar,2010,23,53 »
Fikset innlegget..
Men tenkte på å få inn youtube vinduet i selve innlegget. Så man slipper å gå inn på youtube sin side for å se den..
« Svar #354 på: Ti., 9,Februar,2010,10,28 »
Tøff video ;D
Utlogget sivrt
« Svar #355 på: Ti., 9,Februar,2010,23,12 »
Thanks "Viper"
Et par bilder til av T-Max vinsjen jeg ikke har fått gjort noe med enda. Planen er å vaske alt grundig i diesel og fette det opp igjen med Mos2 fett.
Hadde broder på besøk med "Black Betty" her om dagen og fikk gjort litt småting med den også. Men vi måtte jo ha litt mat også...
Så derfor... Sivrt`s garasjetips mtp pølser:
Man tager en vanlig propandrevet varmeovn med varmeelementer som avgir 4,2 kW, en pølsepinne og en grillpølse. Tre pølsen på pølsepinnen som ved vanlig grilling, legg pølsepinnen mot gitteret på propanovnen og vend pølsen av og til..
Og vips, nygrillede pølser i garasjen Dette kan også kalles restemat for oss pølsekjørere i AOK..
Utlogget sivrt
« Svar #356 på: Ti., 9,Februar,2010,23,20 »
Fikk gjort litt med gamle Ulven idag også. Hadde Nils på besøk så jeg fikk litt hjelp der.
- Fyllte på ny olje på transferkassen.
- Byttet en luftenippel på bremsecalipperen på førersiden foran.
- Luftet bremsene foran og bak.
- Tappet av et par liter kjølevann og fyllte på ren kjølevæske siden det var mest vann i kjølesystemet.
- Monterte nye svarte hjulmuttere med låsemuttere og senterkopper i felgene.
- Flyttet den ut av garasjen så det ble plass til damas bil inne nå om vinteren.
Må fortsatt overhale bremsene rundt om og få sveist opp festet til bladfjøren på førersiden før den er helt kjørbar.. Forhåpentligvis blir det anledning til å ta dette i nærmeste fremtid. Da blir det prøvetur!
Dette blir nå gamleulvens hjem foreløpig..
Utlogget sivrt
« Svar #357 på: On.,10,Februar,2010,23,22 »
Idag fikk jeg renset T-Max girene skikkelig i diesel og satt de inn igjen med Mos2 fett før den ble montert sammen igjen.
Begynte med å skrape av så mye av det gamle fettet som mulig på girene. Kunne sikkert fyllt en kopp med de klissete greiene som girene var satt inn med..
Når alle delene var ferdig skrapet la jeg de i en syrefast bøtte med diesel og lot de ligge en liten stund. Brukte et "oljespillfat" til å vaske delene i med børste og tok siste rest i et annet kar med ren diesel oppi.
Når delene var helt rene ble de skyllt med bremserens og lagt til tørk.. Brukte gummihansker så ikke dieselen kommer i kontakt med huden.
Satte så inn alle tannhjul med Mos2 fett og monterte girene sammen slik de satt. Det kan være en fordel å ta bilder av rekkefølgen på drevene hvis man ikke har gjort dette før..
Mitt arrangement til vaskingen:
Noen av de rene girene:
Det ene giret med litt fett på. Satte inn alle drevene med fett skikkelig før montering. :
Dette ble kanskje litt mye flisespikkeri for mange,men håpte kanskje dette kunne være nyttig for noen som har tenkt å overhale girene på vinsjen sin som ikke har gjort denne jobben før.
Fikk også byttet motorolje og filter idag, håper det vil øke oljetrykket noe da det har vært litt lavt i det siste. Virket bra rett etter oppstart ihvertfall, gjenstår å se om trykket holder seg når oljen blir varm.
« Svar #358 på: To.,11,Februar,2010,17,18 »
Ser ut til å bli bra med vinsjen. Min kunne sikkert også ha trengt nytt fett.
« Svar #359 på: To.,11,Februar,2010,17,19 »
Har du bestillt fanger?
