Skrevet av Emne: Jeep tilhenger  (Lest 4909 ganger)
Utlogget abjornsen
Jeep tilhenger
« på: To., 3,Juni,2010,10,21 »
Ville det være mulig å få godkjent en slik henger i Norge?
http://cgi.ebay.com/4x4-Military-Off-Road-4x4-4WD-jeep-Trailer-/120421476980?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item1c09adea74
Painted  4X5.5 Frame diamond plate floor 18" High Sides
Rear Tail gate
Articulating Coupler and 2" receiver to fit yor application rated at 6,000 lb with 360 degree rotation capabilities.
20in of ground clearance with a 3500lb stub axles and derated to carry 2500lbs custom torsion bar suspension  265/75/16 All Terrains  and 16" Jeep Alloy Rims at this price. Fenders are set to accept up to 35" tires
10 gallon water capacity (two 5 gallon PU Products style water carrier) Front tongue mount
10 gallon Fuel capacity (two five gallon PU Products cans) Front tongue mount
Swing down Jack
Ice cooler and rack NOT Included.
All Trailers are DOT approved with VIN certification and a Flat 4 Connection for lights.
If Customer is from California, Customer will pay sales tax of 8.25% and a 45.00 DMV Transaction fee in return you will receive your Plates directly to you and these are California Perminate plates which are good for 5 years..
Re: Jeep tilhenger
« Svar #1 på: Fr.,11,Juni,2010,22,47 »
Så lenge tillatt totalvekt er under 750kg så skal det går greit. Er en fordel om amerikansk vognkort følger med, så har BT noe å lese data fra. Ellers holder det også at produsent bekrefter data. Den må selv tilfredstille regler om lys.
