Skrevet av Emne: Oppgradering av støtdemperfeste.  (Lest 2373 ganger)
Utlogget sivrt
« på: Ti.,26,August,2008,10,11 »
Lurer litt på å oppgradere festet til demperne bak mtp bedre flex og komfort. Motionoffroad har en løsning der man kan justere demperen i 4 forskjellige posisjoner ved øvre feste. Man får da muligheten til å vinkle demperfestet fra orginal posisjon og mot senter av bilen.
Limer inn det det står på siden:
JKS XJ Adjustable Cross-Over Rear Shock Mount
Fits '84-'01 Jeep XJ Cherokee with 3.5" + Lift
The Adjustable Cross-Over Shock Mount reconfigures the rear shock mounting points for much greater control over shock selection, performance and ride quality. It provides Cherokee XJ owners with four upper shock mounting locations as opposed to the single location supplied by the factory. The improved mounting flexibility makes it possible to optimize shock performance and suspension travel for each unique application.
By relocating the upper mounting points toward the vehicle's center, the shock absorbers are positioned at an angle instead of vertically. A shock absorber mounted at an angle produces a cantilever effect that results in greater compression and extension when measured at the wheels. The reclined shock position also provides a mechanical advantage which improves ride comfort on shocks that would otherwise be too firm if installed in the vertical position.
With the Adjustable Cross-Over Shock Mount installed, the inferior factory bar pin is replaced with a heavy duty stud and washers. This allows proper preloading of the upper bushing, thus improving longevity and reducing noise. Access to the upper shock mounts is also improved, making adjustments quick and convenient. The lower shock mounts remain positioned fore and aft of the axle to prevent spring wrap. When combined with our optional Rear Axle Shock Mounts, the lower mounting points are raised 3" allowing greater suspension travel with the existing shock absorbers.
The rear suspension on Cherokee XJ models is capable of providing incredible axle articulation when properly modified. However, it can be very difficult to find a set of long-travel shock absorbers that are compatible with the vehicle's weight and factory shock mounts.
Most long-travel shocks are valved for heavier vehicles, and when installed on the relatively lightweight XJ the ride quality is simply unacceptable. The few long-travel shocks that are valved appropriately for the XJ are rarely offered in the size needed. In other words, you are forced to make a compromise between performance and comfort.
Product Features:
Four rear mounting configurations enable optimization of shock performance and suspension travel for each application.
Angled shock position produces a cantilever effect for greater suspension travel, while mechanical advantage improves ride quality with firm valved shocks.
Increased suspension travel achieved with existing shock absorbers if Rear Axle Shock Mount is installed at same time.
Heavy duty shock mounting studs eliminate factory bar pin design for improved bushing longevity and reduced noise.
New mounting location increases selection of compatible shock absorbers and improves access for painless adjustments.
Note: Install optional Rear Axle Shock Mount PN OGS922 at same time for greater suspension travel from the existing shocks. Without PN OGS922, it may be necessary to install longer shock absorbers to achieve full suspension travel.
Noen som har en formening om dette? Vil dette hjelpe noe i det hele tatt bortsett fra å lette demontering av demperne?
Her er et par bilder. Burde være enkelt å lage seg noe sånt.. For å forklare litt så er demperfestet orginalt der de platene med to hull på endene boltes til karrosseriet.
Utlogget comanche 88
Sv: Oppgradering av støtdemperfeste.
« Svar #1 på: Ti.,26,August,2008,10,17 »
Høres ut som en bra oppgradering, motion offroad har fått veldig mye skryt for produktene sine og servicen på comancheclub forumet.
Utlogget sivrt
« Svar #2 på: Ti.,26,August,2008,10,20 »
Jeg tenkte å bare lage dette selv, de skal ha 160$ for denne delen på motionoffroad. Det kan jo være litt moro å lage littt på vogna selv også, ikke bare kjøpe ferdige ting.
Men virker som det burde funke. Å få bedre flex fremme er jo lett, bak er det verre pga bladfjørene.
Utlogget Nico
« Svar #3 på: Ti.,26,August,2008,14,00 »
Det greiene der er jo fort gjort å lage selv , ingen grunn til å gi folk penger heller da. Nå det gjelder synspunkter på systemet : Det som skjer når du setter demperene på det viset er at du fjerner masse kraft fra akslen som den skulle skudd demperen sammen med pga at demperen virker som et hengsla stag sideveis. Dvs at om du har meget stive demperer så vil bilen virke mye mykere , men det som egentlig skjer er at demperen mister masse av sin funksjon pga den svinger unna om du skjønner. Så har du en bil som er jævla "stumpete" å kjøre så vil det hjelpe en god del å sette demperene i en eller annen vinkel på akslen.
Nico
CJ-7 Renegade 86.
Utlogget sivrt
« Svar #4 på: On.,27,August,2008,19,34 »
Det var det jeg også regnet med det ville hjelpe mest for. XJ har jo bladfjærer bak så jo høyere den blir hevet , jo mer stumpete vil den bli dessverre..
Føler at min har blitt veldig bra mtp både flex og komfort foran, men mangler litt bak.. Er nok kun coil spring conversion som vil gjøre det vesentlig bedre.
