Skrevet av Emne: Chrysler Recalls Almost 470,000 Jeep SUVs  (Lest 2047 ganger)
Utlogget eivind_m
  • Moss
« på: Sø.,12,Mai,2013,20,11 »
Chrysler is recalling 469,000 Jeep SUVs worldwide because they can shift into neutral without warning on startup.
The recall affects 2005 to 2010 Grand Cherokees and 2006 to 2010 Commanders.
U.S. safety regulators say cracks in a circuit board can cause a faulty signal as the SUVs are being started. If the vehicles shift into neutral they can roll away.
Chrysler says the problem has caused 26 crashes and two injuries.
Chrysler will notify owners and dealers will update software to take care of the problem. Chrysler found cracks in a circuit board that turns the four-wheel-drive system on and off.
Repairs will be made at no cost to owners.
The recall covers 295,000 vehicles in the U.S., 28,500 in Canada, and 4,200 in Mexico. The remaining 141,000 are outside North America.
The company says in documents filed with the National Highway Traffic Administration that it began looking into the problem after a customer complained that an SUV rolled away in January of 2012 after being started remotely.
Mvh
Eivind
Utlogget Rs200
Sv: Chrysler Recalls Almost 470,000 Jeep SUVs
« Svar #1 på: Ma.,13,Mai,2013,17,36 »
jeg vil tippe at dette ikke gjelder diesel-vesjonen?
Utlogget eivind_m
  • Moss
« Svar #2 på: Ma.,13,Mai,2013,23,05 »
Tja, ser ut som feilen ligger i elektronikken til transferkassa og den er lik uansett bensin eller diesel. Så skulle tror det gjaldt våre bilen også.
Samtidig så ser det ut til at "Transfer case control module" har forskjellige delenummer alt ettersom så hvem vet.
Mvh
Eivind
Utlogget Øyvind999
  • Larvik / Vestfold
« Svar #3 på: Ti.,14,Mai,2013,22,24 »
Hvis noen hører noe fra Jeep i Norge er det fint med info. her.
Regner med å selv ta kontakt med lokal forhandler.
....o_o_o_o
./| ,[_____],
|¯l TJ-O|||||O_
()_)¯()_)¯¯¯ )_)
2006 Jeep Commander 5,7 HEMI
Utlogget Julebrus
« Svar #4 på: On.,15,Mai,2013,21,38 »
Dette bryr jeg meg ikke om, har brekk. Hvis du ikke bruker brekket i en bratt bakke så er du ikke særlig smart
Dodge Durango 5,9L 1999- Jeep commander 2008
