Skrevet av Emne: OBD2 TESTER. KAN DETTE BRUKES PÅ ZJ 95 MOD??  (Lest 1272 ganger)
« på: Ma.,23,November,2009,16,27 »
Hei. Kjøpte denne fra USA, sammen med to "nerf bars", og tenkte ikke på at vedkommende hadde en 97 modell ZJ, og er vel redd jeg ble litt hastig og lystig mhht. å kjøpe testinstrumentet. ::) Var jo ikke gratis heller...Noen som kan dette?? Takk.
http://www.zimbio.com/Auto+Care/articles/L05z6PfxmEt/Actron+CP9180+AutoScanner+Plus+Diagnostic
They are compatible with OBD II and CAN vehicles. Additional features include: + Read, record, and play back live sensor data + Bilingual tool with English and Spanish menu items + OBD II compatible and CAN with all 1996 and later vehicles and also works on 1994-95 OBD II compliant vehicles + Reads, displays, and erases generic, manufacturer-specific and enhanced DTCs + On-screen code definitions + Resets check engine lights + USB cable included for Internet updates + Large, backlit, graphic LCD + Displays emissions readiness status + Displays freeze frame data + OBD II code library built into the tool + Displays O2 monitor test + State OBD II check (emissions) + OBD II drive cycle mode + Displays MIL status + Diagnostic monitor test + Retains the most recently scanned vehicle's data and configuration + Battery-powered for review of vehicle's data and configuration + Battery-powered for review of vehicle data off-vehicle + Vehicle information (includes VIN # and calibration IDs) + Help screens + DTC lookup feature + PC-compatible with ability to print + 8 ft. cable, soft case, manual, and Professional Companion CD included
« Siste redigering: Ma.,23,November,2009,16,34 av Fighter »
Utlogget bambus
Re: OBD2 TESTER. KAN DETTE BRUKES PÅ ZJ 95 MOD??
« Svar #1 på: Sø.,29,November,2009,11,44 »
Dessverre, det kan det ikke. Andre generasjon OBD (Onboard diagnostic) kan bare brukes på 96-modell (Facelifted) og nyere.
Mvh bambus
Bambus
« Svar #2 på: Ti., 1,Desember,2009,00,36 »
Supert! ::) Som jeg fryktet. Tenkte ikke før etter den var bestilt. ::) Får vel gjemme den, eller selge den....
