Skrevet av Emne: Cutome 2 x 10" Subwoffer for YJ/TJ + watt forsterker  (Lest 1686 ganger)
Utlogget Dobrikk
« på: Sø.,19,August,2018,16,38 »
Basskasse med 2 x10" og Kicker 300w forsterker
Basskassen er custom laget til å passe i bagasjerommet til Jeep Wrangler YJ/TJ
men passer sikkert i bagasjerommet til andre biler også.
Dimensjoner:
Bredde: 84,46 cm
Høyde: 39,37 cm
Topp dybde 18,42 cm
Bunn Dybde 27,31 cm
Selges Kr 2000.-
Oslo
92029300
Dimensjoner:
Bredde: 84,46 cm
Høyde: 39,37 cm
Topp dybde 18,42 cm
Bunn Dybde 27,31 cm
CX300.1 Mono Amplifier
The CX 300.1 Mono Amplifier is a small, yet powerful and affordable amp.
Using a Class D power plant, this amp features a variable bass boost with KickEQ™, giving you as much as a 12dB of extra bump. A powerful 12dB crossover is included, letting you quickly tune your system to perfection. Use the full range outputs to expand your system with other bass amps, or a full range amp to complete your system.
This CX amplifier delivers as much as 300 watts into one channel.
MODEL
CX-SERIES MONOBLOCK
AMPLIFIERS CXA300.1
Power (watts/ch), 2 Ohm stereo
Power (watts/ch), 4 Ohm bridged mono
Power (watts/ch), 2 Ohm mono
300
CXRC Remote Bass Capable (sold sep.)
yes
Dimensions
(in.) 2-3/8H x 7-3/16W x 8-1/8
(cm) 6.0H x 18.0W x 21
Frequency Response (Hz):
25-200, +0/-1dB
Input Sensitivity:
high level 250mV-10V,
low level 125mV-5V
Signal-to-Noise Ratio:
>95dB, a-weighted, re: rated power
Active Crossover:
12dB/octave, variable 50-200Hz, low pass only
Subsonic Filter
24dB/octave high-pass fixed @ 25Hz
KickEQ™ Boost
variable to +12dB, centered @ 40Hz
