Skrevet av Emne: Mopar heve kit for XK  (Lest 1640 ganger)
Utlogget Cloudhanger
« på: On.,30,Oktober,2013,11,06 »
Mopar 4" heve kit, kanskje noe for de med XK
Det burde vel være mulig å få godkjent via Jeep? ...ettersom det er Mopar produkt, skulle en kanskje tro de ville tøre å gå god for det.
http://www.jeep4x4center.com/jeep-lift-kits/mopar/commander-xk-4-inch-suspension-lift-kit.htm
Mopar Performance 4" Lift Kit with Billstein Shocks
2005-2010 Jeep Commander XK
The front lift is accomplished with strut towers; rear lift via new coil springs. Thin preload plates install on top of the springs to boost spring rate slightly and offset the increased load / leverage generated by heaver and wider tires and wheels. The lower control arms and differential are relocated via brackets then new steering knuckles span the increased distance from the relocated lower control arms to the upper arms, which remain in the stock location. Brackets relocates the affected rear suspension components. Lift Kits include a plug-in module to ensure functionality of Jeep's Electronic Stability Program.
Utlogget Øyvind999
  • Larvik / Vestfold
Sv: Mopar heve kit for XK
« Svar #1 på: To., 7,November,2013,15,36 »
Dette er vel Superlift kitet som er rebadged til Mopar. Hadde vært artig å få godkjent dette ja :)
....o_o_o_o
./| ,[_____],
|¯l TJ-O|||||O_
()_)¯()_)¯¯¯ )_)
2006 Jeep Commander 5,7 HEMI
