Kjøp - Salg - Byttes => Salg - Jeepdeler => Emne startet av: Cedric på On.,16,Mai,2012,14,28
Tittel: DIFFERENTIAL HOUSING SPREADER, DANA 30-80
Skrevet av: CedricOn.,16,Mai,2012,14,28
DANA 30 THRU 80 DIFFERENTIAL HOUSING SPREADER
Will work with all Dana 30, 44, 60, 70 & 80 series differentials (most all Jeeps and others)
I used this Spreader to install ARB Air-Lockers on my 97 Jeep Wrangler the right way! Don't hammer them in! Do it like the PRO'S, SPREAD-IT instead! Set factory bearing preload the right way!
Main spreader bars are solid 2-1/2" x 1" thick 1018 CR steel. Spreader adjuster uses a Torrington Bearing for gall free operation. All bolts and nuts are Grade 8 hardware.
POWDER COATED FOR DURABILITY.
Weight: 17kg (37lbs).
http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=34942913
Gi meg tilbud/Send offer.
