Generell kategori => Generelt => Emne startet av: CJ-7 på On.,23,Januar,2008,23,15
The Jeep is back in the front line... Vol: II
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/j8_black2.jpg)
Da er nok en gang Jeep “back in the front line” vel ikke helt… Denne Jeepen J8 vil ikke være et kjøretøy i frontlinjen. Mer et stabs kjøretøy og andre ”lettere” gjøremål.
Motor: 2.8L Tdi. 118 kW (158 hp) og 400Nm.
Gir: five-speed automatic transmission
Aksel front:Dana44? bak: Dana 60.
Fjærer. Front: Skrufjærer. Bak: Bladfjærer!!
The frame of the Wrangler Unlimited is reinforced for increased ruggedness and to allow greater payloads – up to a maximum of 1,339 kg (2,952 lbs.). Axles, brakes and suspension components are engineered specifically for more demanding military and civilian government use, including utilizing a leaf-spring suspension!! 8) system in the rear. The J8's Command-Trac® four-wheel-drive system allows maximum versatility and performance in both on- and off-road conditions.
The Jeep J8 is powered by a 2.8-liter four-cylinder turbo-diesel engine that produces 118 kW (158 hp) and 400 N·m (295 lb.-ft.) of torque, providing towing capability of up to 3,500 kg (7,716 lbs.). The engine is mated to a five-speed automatic transmission. The J8 also features a unique air-intake system with special filtration and a hood-mounted snorkel that enables the J8 to ford water up to 762 mm (30 in.) deep and operate in sandstorm conditions for up to five hours.
The Jeep J8 is available as a two-door with an extended pickup bed for personnel or equipment transport, or a four-door multipurpose vehicle.
Tow eyes and heavy-duty bumpers allow the Jeep J8 to be easily transported by airplane or helicopter.
Only for military and civilian government use. Sorry, no civilian sales will be offered
The Jeep J8 will be produced in a Chrysler LLC joint-venture facility in Cairo, Egypt, and will be available beginning in spring 2008.
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/jeepj8_hi004.jpg)
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/j8_black.jpg)
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/jeepj8_hi001.jpg)
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/jk%20kulepennfj%E6rer.%20vs%20j8%20leafs.jpg)
(http://www.jeepclubnorway.no/images/stories/Lokalavd05/Oslo/petter/Frontline/j8%20vs%20jk.jpg)
Opp fra glemselen :) Klikk inn på:
http://www.jeepclubnorway.no/index.php?option=com_content&task=view&id=24&Itemid=35
