Quadra-Trac trenger ikke slippmiddel, iallefall ikke foran.
ZJ/WJ Quadra-Trac har åpne differ foran og bak mens WJ Quadra-drive har Vari-lok hydrauliske diffbremser foran og bak (og trenger ekstra slippmiddel bortsett fra om man bruker av Royal Purple Max-Gear ifølge erfaringer).
WJ har dessuten ikke viskosekobling i transferkassen slik som ZJ har. Ble i WJ erstattet med en type som ligner den i Quadradrive-diffene.
Mulig at din ZJ Quadra-Trac har LSD (vanlig diffbrems) bak. Men da skal jo uansett vanlig diffolje for LSD funke fint.
Husker heller ikke på sparket om ZJ Quadra-Trac har Dana35 eller Dana 44a bakdiff, men det er jo bare å ta et bilde av den bakfra. Mulig det avhenger av motorvariant, årsmodell osv.
"Exclusive to the Grand Cherokee ZJ was the introduction of Quadra-Trac system with permanent all-time four-wheel assistance. This was optional on all models."
"In 1993 Jeep introduced Quadra-Trac on the Jeep Grand Cherokee using the NP249 transfer case. The transfer case utilizes a viscous coupler which provides smooth and efficient four-wheel drive operation on dry surfaces. When a differential in speed occurs between the axles, heat buildup causes the viscous coupler to transfer power to the slower axle. It is similar to several passenger car systems, but with a low-range gear for serious off-roading. NP249 transfer cases used the viscous coupler to transfer power in both high and low ranges.
Applications:
1993-1995 Jeep Grand Cherokee (ZJ)
In 1996 the NP249 was replaced with the New Venture Gear NV249 transfer case which added a low-lock capability, meaning a hard gear transferred power in 4LO (front and rear drive shafts are locked at same speed in low range).
Applications:
1996-1998 Jeep Grand Cherokee (ZJ)
https://en.wikipedia.org/wiki/Jeep_four-wheel-drive_systems
