Grom kjøler/fryser som dekker alle behov. Kjøler ned til -18 C
Digital temp-setting
Trinnløs kompressor, bruker lite strøm (0,8A se spec under)
Battery Protection System, slår av kjøleboksen før bilbatteriet ditt er tomt.
Kampanjepris kr. 5550 + mva = 6938,-
Gjelder så lenge lageret rekker.
Spesifikasjoner:
47 Litre Fridge Freezer Specifications
Capacity: 47 litres (72 x 375ml cans)
External Dimensions: H508mm x W380mm x D705mm
Internal Dimensions:
Fruit & dairy compartment: H206mm x W285mm x D151mm
Main compartment: H401mm x W285mm x D337mm
Weight: 22kg
Cooling Capacity: +10°C to -18°C
Power: Built-in 12/24V DC and 100-240V AC power
Integrated battery protection system
Current Draw: 0.87 amps/hour*
*Power consumption tested at 3°C cabinet temperature, 26°C-31°C ambient temperature range, test duration of 66 hours and supply voltage of 12V DC
Weblink:
http://www.arb.com.au/products/arb-freezer-fridges/Kontakt
BG NOR A/S, tlf. 22905770
http://www.bgnor.comamund@bgnor.com
